Quote: I agree. If you listen to all the old ladies on this board you will end up with $5000 stock 383s. Now if you're turning it to 9500rpm, things change. But we seem to forget that engines are just lumps of iron and aluminum. The fact that the guy's local and you had a good feeling about it even after listening to all the carping means it's most likely going to work out for you.
R.
God forbid people on the board look out for one another .
I know of at least one board member getting taken by another board member with a TAILLIGHT WARRANTY ...
I personally looked at the engine and passed on it because I didn't like what I saw/was told along with said taillight warranty, the member that bought it was so lucky ...
