p1762--
Transmission does not shift correctly. Trouble code P1762.
Average Reported Mileage:
100498
Tests/Procedures:
1. Check the voltage of the governor pressure sensor with the Key On Engine Off (KOEO). It should be about 0.5 volts.
2. If higher than 0.8 volts, check the transmission temperature sensor reading.
3. If it is not accurate, check the sensor ground to the governor pressure/transmission temperature sensor.
4. If the transmission temperature sensor is reading correctly, replace the governor pressure sensor.
