Do you have the correct/bent drag link on it and not the straight slant 6 drag link?
On a 67-76 A-body there is no such thing as a /6 centerlink.
That is only for the 66 and earlier cars that they made a seperate centerlink for /6 and then V8 cars.
Got it. Thanks for the update.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
