well i am going to try and make this fridays last tnt for the year. but i noticed my front tires are getting weather cracked pretty bad, so i need to change them. the ones i have on it now are the M/T front runners in a 26/6.5/15 biase ply. i am running M/T 275/60/15 et drag radiales in the reaer. so i would like to put the same tire on the front but dont know what size metric tire will fit. the car is a 73 dodge dart. I found a set of 165/80R/15 tires .will those work on the 3.5 inch wheel? if not what size do you recomend??? thanks Mopar65
