I am not familiar with a tapered seat plug, but it does have the taper on each hole. I had these heads machined about 6 years ago and that shop must have added the taper. I have been running the standard type of plug with the gasket ever since. Are tapered plugs easy to find? These are -7 NGK's.
Thanks allot for your replies.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
