under load
If you want an intelligent answer you could be more specific...they don't charge by the word here.
If it slips in all forward gears but not Reverse the rear clutch is the problem; if it slips in Reverse too you have a pressure problem. Either or both could be related to the pump change.
The INTERNET, the MISinformation superhighway
