You guys are right about the 413 truck motors. They dont look like your basic RB engine. My dad has a 66 CT800 with the 413. The distributor is not in the block. Its in the governor, which is in the same hole that the distributor should be in. So its huge as stated above. I was going to say too that I thought the crank hung out the back of the block more than the other RB's
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
