All the 400 and 360 flywheels are exteranlly balanced Have it nuetral balanced before using it, look at the crankshaft bolt pattern to make sure the flywheel will bolt up to your crankshaft . It should be a 6 bolt crank pattern but some of them are 8 bolt like the early motor where
