Once Bucky got it in his shop, they stripped the car to bare metal, and did the necessary floor work. Cole left the existing roll cage that Butler installed in 1970, and was careful to cut the floors to fit around the bars. As mentioned earlier, the second down bar in the entry was removed, since that second bar had been installed later, possibly late '71 or '72. The cage in the restored car is as it first rolled out at Indy in 1970.
