'68-'70 Plymouth b-body - the fader switch was mounted on the bottom of the dash frame. '68-'70 Dodge b-body (W/O rallye cluster) - the fader switch was mounted in the switch panel to the right of the steering column
You sure this is right??
My 68 road runner has it in the switch panel to the right of the steering wheel.
