No, no difference. However, Galen's book lists 71 HP 383's to have Carter AVS carbs, part number on the build sheet as #44. My 71 Satellite with the N code HP 383 with 4 speed and A/C, lists the Holley R4667 , part number 48 on the build sheet. Same 4160 Holley with or without A/C. The book does not list it as an HP, but it is. Galen's book is confusing with listing the Carter 6125S for the 71 383 HP's.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
