how far are the studs from the block?
I used the one from DB Electrical. Works nice and spins the motor over fast. The terminals are close to the block but not touching. I just hooked up the wires first then mounted the starter.
Ditto,
I've used 2 from them.
1 on a 484 hemi and the 2nd on a essentially stock 440 . both fit and worked perfect.
http://www.ebay.com/itm/NEW-MINI-MOPAR-D...=item1e67a4f65a
