Has any one found a brand of mini starter that dose not cost a fortune,
mounts correctly and works to crank a BB with 10:1 compression? All I've
heard are nightmares about failure, overheating, mounting issues and
terminals that are too close to the block. I have a 383 with a TTI header/exhaust system hung on it and messing with starter swapping is
a real issue I wish to avoid.
