Quote: A big block built to handle that amount of power with twin turbos would cost more then 10 grand.
Realistically whats the most power you could get from a wedge stroker with turbo? could you at least put 800 hp and torque to the wheels? What would be the limit and still be reliable and streetable. Also are there any twin turbo setups or regular turbo systems that will work with a wedge motor or even a hemi?
