Above idle see if the boosters are dripping. Mine are with a stock 318 mech pump. May need a regulator. come payday I'm getting a holley low psi one for my 1406 Eddy.
I don't know what you mean by the boosters. Also, what did you mean by getting a holley low psi for your 1406 Eddy? Do you mean in exchange for?
The boosters are the the round things in the center of each barrel in the carb. In the first five seconds here, you can see them spitting fuel out (hope Cal doesn't mind if I link to his video ) http://www.youtube.com/watch?v=v-ucCl8KXoU&feature=relmfu
RR is probably talking about getting a holley fuel pressure regulator.
If you ever find yourself in a fair fight, your tactics suck.
