You can get well into the 11's without a stroker.
Little brother has a 9-1 360, ported eddies, weiand excellerator, dinky small tube headers( its a 66dart gt) 750 holley, and a healthier than it needs to be flat tappet cam and runs 11.40's without working up a sweat.Can drive the thing anywhere.
I have a bauudy who ran 10.90's with a comp cams 525/305 hydralic cam in a 360 but had some compression with eddies that werent ported. Good eddies and matching parts and 11's are real easy.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
