In short the low band apply is GOOD it keeps the trans from exploding if you do a burnout wrong. What you dont want to do is let off the gas at high RPM in 1st gear. You do want to do a burnout starting in 1st, but make sure it shifts into 2nd and or even 3rd before letting off the gas.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
