Have you checked the toe change thru the front end travel?
It may be more on one side than the other. If there is a lot and you are setting it at 2" up it could be toe out at static height, and worse on the brakes when the front end dives.
Just another thing to check, hope you find it.
"Just a Bracket car dressed up like a streetcar"
