brakes not draging lower control arm bushings replaced 3 years ago strut rod bushings same time
I guess all I can do is see what it does going down the track
I will be the guy bouncing off the walls at MMW at Gateway Motorsports Park in 2 weeks
That would not be my suggestion . You need to find the problem - and it is a problem. Got the wheel alignment specs? Assume it was a 4 wheel alignment? As said, remove the rear preload if you have any. Did you try switching the rear tires? Find a place that will put the alignment "on the money", not "within spec". Torsion bars adjusted ( preloaded )the same amount? With the car sitting level and at ride height, is the center link parallel to the ground? Stuff to check.
Fastest 300
