Another thing to consider is your charging system. If it is stock the MB fan will probably be to much for it.
It draws 39 amps running at full speed. I ran a power lead from the alternator through a fuse and into the the fan.
Running on the controller it shouldn't draw anywhere near that kind of power.
http://www.youtube.com/watch?v=8aGq7f0SSYk
A typical square back alternator runs 60 to 78 amps.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
