Seems like reverse cooling should help the overall head temp, and might be enough to take care of it also, maybe?
What if you could add lines that direct coolant fluid right out of the waterpump housing to that area of the head??? Instead of letting more coolant flow out of there, let cooler fluid in, being the idea.
R.I.P.- Gary "Coop" Davis 02/09/68-05/13/04
