The fender tag options look pretty typical of a 70 Charger R/T. This is not a 2 fender tag car as the stripe code & 26 are usually the last items on a St. Louis tag. The top color is on the tag as EK2, the power brakes are also noted as B51....you did not show the A32 option code in the correct order so I assume this car did not come with it. I assume you have a D32 as the second option code noted on the lowest line. This is for auto trans. Car sounds nice as optioned. How about a few photos?
