use the steel forks - the brass one's have a tendency to snap off at the shaft. Since the steel forks only came on the slider style side covers they are made with an additional smaller shaft on the ends - you just cut those off.
on the detents you want to round off the sharp edge off on both sides of the neutral position and do the same on the leading edge on the 1, 2, 3 and 4. This is so the detent ball will slide more easily when you shift. DO NOT grind the edge where the ball stops!
The thing will shift so smooth you won't believe it.
Stanton, Do you have any pictures of this mod, and where/what to cut grind? Im thinking of doing some mods to mine.
