The LA plant stopped producing E-bodies some time in May of 1970.
Hamtramck produced N95 E-body models for the 1970 model year also.
If you have a March 1970 or later E-body, note the SPD on your tag / broadcast sheet, the actual build month from your original door sticker & whether it has the dimples or not. That will be a start.
