in a 68 Charger ........... 505 stroker around 10.5 comp............ Cost is not a concern ........ what should I do......
Thanks, Joe
That's a weighty kinda B-body. I'd go Max Wedge Indy EZ's if it were me. They have the long valve/bigger dogleg port to feed that stroker. Header fitment isn't as big an issue as "-1"'s, standard rocker offset, but you'll need an intake too.
R.I.P.- Gary "Coop" Davis 02/09/68-05/13/04
