Thanks a lot for all the replies
Dogdays,
The pistons are flat ,stock style,TRW L2388,1.926" comp distance .
The deck is not exactly the same in all the cyls,but they are between .068" wich is the one most closer to the surface and .074" that would be the most deeper in the hole.
The Whiplash cam lift is .518".
What i thought,or at least what i have read in some web page, is that the Alu heads subtract one pound from the compresion,but they compensate that loss of power in other ways.
So if it is 9.30:1 would it go to 8.30:1?
Here is a link to Youtube about a 66 Coronet wich is running a very similar set up,440 engine ,Whiplash cam and 452 heads.(The cast iron ones ?)The engine is from a motor-home,8.5 comp ratio and the owner seems to be very happy with it...
http://www.youtube.com/watch?v=MjeCyVvg4Ss
