Might want to pull your valve covers and make sure that you don't have a cam lobe going flat. By pulling of the coil wire you can crank the engine and watch each valve go up and down to eliminate that possibility. I think it is hard to do a compression test on a 440 with headers, a compression test would be best. Good luck with it.
