I know it was not mentioned but if rpm is not the issue why not a hydro-roller? I almost went that route vs a std roller but even the best kit I could find was under 7k rpm and I needed a bit more. So I went with the mech roller.
Prior to that a solid worked much better then any std hyd cam ever could.
