Another
What do that bar that connects to the crossmember to the inside frame rail connects to or do it just dead head into the frame?It looks good.............
It goes thru the trans cross member part of the frame, then turns & goes thru the other part of the front sub frame & then up on an angle to the inner rocker panels with plates welded to the inner rocker panels. I think I have pictures of that too. I'll look.
here is a pic of the frame connector looping over to the rocker bar tieing into the rocker & the "A" piller bar coming down into it.
Going to be filling the two open hole with sheet metal.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
