one thing you may want to look into while still in fabrication stage is the 25.3 spec. the couple extra bars will allow you to cert. to 6.0 instead of the 7.50 with the 25.5. you may never use it but is nice to have if you ever do upgrade down the line. also one mistake i made is checking for clearance on the dash bar (same as yours) the stock cluster will not fit
