What happens to an oil filter with a bypass that's rated at 20 GPM when it gets hit with over 20GPM??? After my 1st lifter failure,there was contamination throughout the entire oiling system embedding in all the bearings.That's when I did my homework on oil filters and changed to a non-bypass style filters.The Moroso filters flow 16 GPM each.My second lifter failure resulted in no contamination getting past the oil filters.
HEMI-ITIS has no cure. My condition is fully BLOWN!!
