Re: R3 sonic results, need help
[Re: mopster]
#1130838
12/11/11 03:49 PM
12/11/11 03:49 PM
Posts: 1,784 PA
W5DART66
PA
I have a brand new siamese R3 48* tall deck that I just got back from sonic test, and I´m not very pleased with the results. This is 3.99" bore as it comes, and it seems to have core shift to every possible directions leaving some areas a bit thin. Thinnest spot is in front of cyl 1. Outer walls are thinner than inner walls on both sides, worst spot on major thrust sides is in the bottom of cyl 4.
Are these typical results for R3 block or do I have a bad one? I hoped that I could build a 4.185" bore 700-800hp N/A engine at first, but leave room for another rebuild, and if I decide to, be able to go forced induction and about 1200-1400hp power level. Not going to happen with this block?
I could fix some of the core shift by moving the bores away from the thin sides. My machine shop guy told me he could move the bore centers individually up to .060" if my head gaskets and combustion chambers allow it. I don´t think the combustion chambers will be a problem since I have untouched W9 heads and I will do all the headwork myself and I can fit the chambers to the cylinders. The head gaskets may be a problem, and I probably should get them first and do some measuring. I think the left side bores should be moved some towards back, and both sides should be moved inwards. Could this be done and which head gaskets should I get?
I could also do a smaller bore like 4.165" for the first build if required. Also I could do a partial fill since the thinnest spots are all in the bottom of the bores.
Numbers don't look that bad to me I would run that block at 4.200 with out any worries about it. Looks like you would be over .200" thick every place but a non-thrust on 2 cylinders. I was .135" at 4.180 on my engine masters 411CI W8 engine this year. I was at 800HP 80 pulls on dyno and 15passes in the car so far. that engine was 14.1to1 and only a 255* at .050" intake lobe so it has lots of cylinder pressure.
Entire Thread
mopster
12/10/11 01:06 AM
MR_P_BODY
12/10/11 02:00 AM
Hot 340
12/10/11 02:08 AM
Leon441
12/10/11 03:40 AM
mopster
12/10/11 08:49 AM
Oyvind Mopar
12/10/11 11:25 AM
stevet340
12/10/11 01:37 PM
rickraw
12/10/11 02:47 PM
ParadiseCuda
12/10/11 05:54 PM
moparacer
12/10/11 06:02 PM
mopster
12/10/11 08:34 PM
instigator
12/10/11 08:48 PM
moparmacka
12/11/11 05:00 AM
moparmacka
12/11/11 05:14 AM
Performance Only
12/11/11 05:59 AM
Performance Only
12/11/11 06:21 AM
Performance Only
12/11/11 06:23 AM
408Dust
12/11/11 02:33 PM
mopster
12/11/11 04:42 PM
mafo
12/11/11 05:08 PM
rickraw
12/10/11 05:25 AM
WHITEDART
12/10/11 05:48 AM
MR_P_BODY
12/11/11 05:19 PM
W5DART66
12/11/11 07:49 PM
mopster
12/11/11 09:05 PM
Leon441
12/11/11 10:21 PM
moparmacka
12/12/11 10:49 AM
