Get it to a TRANSMISSION shop and have them scan it, including a CVT (clutch volume test). They can shift fine but if the computer sees that it takes too much fluid to apply the clutches it assumes clutch wear and goes into limp in mode. Most regular scanners or code readers don't read this.
Free advice and worth every penny... Factory trained Slinky rewinder.........
