Always tub it to fit a little bigger, but IMO a 14x32 should be just fine. And 14 or 15 wide rims.
From what I have seen, the best 10.5 tires are 31" or 33", not the 29.0-29.5. Again use a wide rim.
Yep I am also starting to think a wider rim is better as it lets you run more air pressure in the tire without pushing the center of the slick up.
Going to experiment with it in the spring when I buy a new set of slicks for my car.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
