I have 1 last set of cuda louvers I can sell you.
I believe these are way better quality than the others available out there...others that have bought from me can probably chime in.
I did this because I wanted some for my own cuda clone, and when looking at the repros at the nats that were selling for $1200 and looked all crooked and wavy... I said NO WAY IM PAYING THIS MUCH FOR SOMETHING I CANT USE, IS ALL WARPED AND LOOKS BAD! So I lent some originals from a friend and copied them as faithfully as possible, down to the welds and eveything. And made em fit right and look nice.
Other repros are all wavy and wont lay right on your car without some tweaking...also the louvers are all wavy and not parlallel to each other..and on these louvers its not easy to correct that because they are all welded and when you try to tweak them to make em nice and parallel they all get all over the place.
I have one last set of cude louvers, its my last set i wont be making anymore.
Also my repro hinges are hollow at the back like the originals, the other repros are cast solid.
email me at
domingo426@gmail.com if interested
