pull #1 plug and bring #1 piston up to TDC and check to see if the timeing mark is correct.
it may have a slip damper ring and not want to time with the marks
while you have the plug out,piston TDC,check to see were the rotor is pointing in the cap to rule out a jumped chain/tooth off.
