If you have an electric water pump, don't run a thermostat or a restrictor.
please explain why not. Doesnt an electric pump move more water than a mech at idle? Im about to use both a stat and the heater.
You can leave the pump running and completely cool the motor down. If the thermostat closes, you can't circulate water. Meziere says NOT to run a thermostat w/ any of their pumps.
They may say not to, but that doesn't mean it can't be done. Street driven with a Meziere for 6 years with a 160º stat with five 1/8" holes around the perimeter, never a problem. The holes make all the difference.
Gone to the dark side with an LS3 powered '57 Chevy 210
