Quote: if you are going to use a girdle, the only one worth buying is the bcr piece in my opinion.
Becareful of the type that use washers and spacers to make up the difference between the mains and the pan rail as those really dont do what you are looking to accomplish
Josh, what does the BRC one do that the others don't. I got one from Hughes on mine and it uses spacers and shims between the plate and the main studs.
