The solonoid is there so that when the kill switch is turned off the solonoid turns off which turns off the alt. So it wont back feed and keep the engine running.
I had to reword my other post about the solonoid so others may not understand this reply however, there is nothing to back feed. If you contain the output of the alt to the battery and no other circuits, it can't feed anything else, specificly the ignition. Not trying to start anything here, but I don't see the need for the solonoid. Unless the voltage is feeding through the field wires??? I've wired mine like this, however I use a single wire alt. Maybe thats why it work for me. Hmmm...
