Since I am "search" challenged, I need some help.
I have my battery in the trunk, cut off switch, and the alt wire run to the back also. I saw a posting, nice diagram, awhile back about using a ford solenoid to run the alt wire to, so when you flipped the switch it killed the engine, like you are supposed to have, and it kept the alt wire from being hot all the time. How are the 2 little studs wired? I know what goes on the 2 main studs, but how to wire the 2 little ones. May sound silly but I don't to hook something up wrong not knowing, better ask, then be wrong. Thanks Bill
