Quote: About the hardest part of doing a /6 to 318 swap is getting the lopsided lump out of the car without trashing the bulkhead connector, after the 1st time you learn to disconnect it and push it inside the car.
Thank you for that tip.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
