Since your buying a good cam and lifters why not buy a decent set of adjustable rocker arms so you can get the best performance out of your cam Any time you replace the stock cam with one with more lift you change the distant from the end of the stock rocker arm to the cup in the lifter, which makes the stock stuff not fit properly anymore Buy the good stuff, rockers, and pushrods
