A set of crane ductiles would work with only minimal clearancing for the rockers needed .
What heads are you going to run ?
Probably some 452's. Where did you have to clearance those
rockers?
This works well and you don't have to move the baffels.
That's all the needs to be done, nothing needs to be done to the rockers just drill he baffles to clear the adjusters.
