solid machine work and balance it, oil systems are pretty good for the most part but use a good pump drive (hardened) you can open up some oil passages to get more oil to the bottom end, full groove mains will provide more oil to the rod's but will sacrifice oil pressure.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
