Quote: my CTD gets 24 mpg @ 65 MPH with 2-5 pounds of boost
Don't bring a diesel into the conversation or everyone will get confused
Diesels do not have a throttle blade and therefore don't pull vacuum. Your CTD will also build boost going downhill with your foot off the accelerator. A gas engine will never do that. Diesels also have a very wide range of operable air to fuel ratios, running as lean as 50:1 at idle.
my bad my diesel truck gets more milage than my gas truck even with out boost
