From the 4 inch throw small block posts on here over the years It seems that the smaller cid 408 to 416 with good heads 300cfm to 330cfm make peek power around 6500 to 6800 with cams in the 260 to 270 @.050 range.... There really are too many variables for a rule approach
Well my cam is 276 @ .050 and I need it to turn 7000-7200. I don't think that will be a problem.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
