Quote: If you block off that nipple you can starve the bowl of fuel.
I think you're wrong on that one.If you replace the bowl with the standard bowl with the rubber vent cap on the same carb,you would basicly have the same carb without a vent tube.Also,some 69 1/2 and early 70's big block carbs have no venting at all.
