Quote: i cld local parts house, they cannot get these, i have found a used set on ebay. here we go again
A USED set ???? are you nuts ? you pretty much have to destroy them or the LCA to get them out...
Yes you can buy new bushings at the local parts store , better yet go on ebay and buy a set from bill rolik , he is a member here , they are better quality , BUT you are going to have to remove the lower control arms to do it , may as well get a set of torsion bars and do then on both side
