OK cool, I'll give that a try. Thanks!!
I did it head on the engine... used about a
8" length of tig rod... was easy...good luck
the reason I wouldnt go with the sand paper... its
already too small... sand paper takes material off...
you need to go larger... this is a cheap mans knurling
