That may work but if there is any pressure in the crankcase it could(more likely will) blow out every gasket in the engine. I will be using a setup like I had on my 8 second Falcon but only on one of the valvecovers and a filtered vent on the other valvecover like this,
[url=http://cgi.ebay.com/ebaymotors/EVAC-SYSTEM-CRANKCASE-VACUUM-DRAG-RACE-EVACUATION-/130570012054?pt=Race_Car_Parts&hash=item1e66944596]http://cgi.ebay.com/ebaymotors/EVAC-SYST...=item1e66944596l]My
Then just use these. Just make sure they are away from any oil being thrown around under the valve covers and the tubes are pointed AWAY from the exaust. Which Im sure you already know. BUT catch cans can be made with almost anything, and I've seen them made with rockstar cans to beer cans. A real simple deal honestly, you could even make your own custom, and may have the stuff laying around to do it.
